The Far-right Delusion
Exactly - the records do not go back far enough. And by the way part of the scam is that its CO2 that is the problem, which is the only way they are grifting the man made rubbish.
I prefer the world wide scientists version
So what evidence do you have? Let's look at it ?
Idiots point to 100s of years of data for a 4billion year old planet - they blame it on CO2 - which can be taxed of course. The Co2 is the scam.
No. The idiots decide they know better than scientists from all over the world
The process by which carbon dioxide warms the atmosphere has been known about for almost 150 years. Only an idiot would deny the basic scientific principle.
500 million years ago concentrations of CO 2 in the atmosphere 4,000 and 180 ppm during the glaciation of the last two million years.
Currently they stand at around 422.77 ppm
Who found that out? Was it scientists by any chance? Where did you find the info?
Thought you said records didn't go back far enough.
How was the comparative speed of change ?
And at some point all life on earth was wiped out or at some point the earth was unfit for habitation.
Do you see where folk are going with it yet, durr.
You do know that we are dangerously close the earth to not have enough CO2 to sustain plant life.
The ambient level of CO2 in the atmosphere is approximately 400 PPM. At 100 PPM of CO2 the rate of photosynthesis would be stopped completely. At 150 PPM the plants begin to respire, and photosynthesis is stopped. At this low level the plant will no longer be able to obtain CO2 from the atmosphere and photosynthesis is restricted. The plant will eventually use all of the CO2 present, photosynthesis will stop and the plant will die.
The rate of photosynthesis at 350 PPM will be consistent with growing conditions outside of a controlled environment, given that ambient levels of CO2 in the atmosphere are approximately 400 PPM.
With no other limiting factors such as heat, light and nutrients the plants will photosynthesize at a rate consistent with ambient conditions (i.e. outside of the greenhouse). There may be a slight increase in photosynthetic efficiency due to the higher than ambient CO2 level, however this increase will probably be insignificant. The level of 1000 PPM CO2 is very close to the optimum level of CO2 required, given no other limiting factor, 1200 PPM, to allow a plant to photosynthesis at the maximum rate.
