The Far-right Delusion
You do know that we are dangerously close the earth to not have enough CO2 to sustain plant life.
The ambient level of CO2 in the atmosphere is approximately 400 PPM. At 100 PPM of CO2 the rate of photosynthesis would be stopped completely. At 150 PPM the plants begin to respire, and photosynthesis is stopped. At this low level the plant will no longer be able to obtain CO2 from the atmosphere and photosynthesis is restricted. The plant will eventually use all of the CO2 present, photosynthesis will stop and the plant will die.
The rate of photosynthesis at 350 PPM will be consistent with growing conditions outside of a controlled environment, given that ambient levels of CO2 in the atmosphere are approximately 400 PPM.
With no other limiting factors such as heat, light and nutrients the plants will photosynthesize at a rate consistent with ambient conditions (i.e. outside of the greenhouse). There may be a slight increase in photosynthetic efficiency due to the higher than ambient CO2 level, however this increase will probably be insignificant. The level of 1000 PPM CO2 is very close to the optimum level of CO2 required, given no other limiting factor, 1200 PPM, to allow a plant to photosynthesis at the maximum rate.
Where are you getting your info?
And at some point all life on earth was wiped out or at some point the earth was unfit for habitation.
Yeh that was when the CO2 dropped -- CO2 is the scam to tax you by. Methane and water vapour are far more involved in climate change that Co2 but your farts and breathing water vapour are more difficult to tax. But I am sure that labour and the green loons who finance labour will find a way.
I think folk are trying to tell you that if we carry on at the current rate of change - humans will die out.
Oh that's rich from the person who creates more CO2 than anyone else on the forum with their totally unnecessary trips to go skiing - what a disgusting hypocrite - he is even so proud of it that its his profile picture - hypocrite
What was? Which Earth period are you referring to?
This from the worst forum climate hypercrite. Probably the only reason you give a jot is so you can continue getting on a plane for your unnecessary trips to go skiing -heaven forbid that your slopes do not have enough snow this year - hypocrite
But you think it's all a scam. Why would there not be enough snow?
We tend to ski in altitude resorts or glacier resorts these days. Some years when snowfall is scarce, those that are lower altitude can suffer with a lack of snow.
Hitting a patch of grass is like slamming your foot on the brakes.
When I see climate change deniers trying to discuss the science, it reminds me of the great line from a Fish Called Wanda:
Wanda : But you think you're an intellectual, don't you, ape?
Otto : Apes don't read philosophy.
Wanda : Yes they do, Otto. They just don't understand it.
Not one of you climate scam believers have an electric car or a heat pump - do you
It was? During which earth period are you referring to?
More from the forum climate hypocrite with more air miles than Richard Branson look at the state of this - almost 200 posts about his hypocritical non necessary flights and he has the brass neck to talk about climate chance - hypocrite. Think I am going to make you a new badge. https://www.diynot.com/diy/search/5829997/?q=ski&c[users]=noseall&o=relevance
I think all the ski lifts we use are electric. (y)
