the MK split load cu (screwfix!! £79-99)
6 Sep 2004
Cumberland
does any-one have an opinion on the MK split load CU offered by screwfix at the moment for £79-99 complete with RCD and 10MCB's?
I'm asking as I've been asked to refer one and having never installed one am somewhat reluctant even though on the whole I've found MK gear pretty spot on and the price does'nt seem too far out!
http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=98634&id=64020
comments guys/gal's glady appreciated :?
i gathered from other forums the current mk CUs are a bit flimsy during install but are fine once screwed together
it is a very good deal containing all or almost all the breakers needed for a domestic install and a few spare on top of that
shouldn't they be beside the others, not on top? :lol: :wink:
I purchased one a couple of weeks back as I'm doing a total rewire of my bungalow
Thr casework is flimsy, but aren't all manufacturers cost cutting to remain competitve in a cut throat market ?
My only problem was deciding how to fully utilise 10 ways
So far i have
Downstairs ring main
Kitchen ring main
Bedroom ring main
Multimedia room ring main
Cooker
Shower
Radial for fridge freezer
Upstairs light
Downstairs lights
I think that leaves one spare - don't have an immersion heater so can't think what I will ever use it for
Feed to my shed ??
lol, try living here, full 21way MK CU plus another one with 2 ways used......and i need to add more circuits! you really can't put enough spare ways in!
thanks all, my customer is supplying himself via screwfix and I have the job of swapping his CU's over just thought i'd do a bit of "background info" on the product having never fitted one before
appreciate the responses
thanks again
spence :D
securespark said:
What do you normally fit?
whatever the customer asks(wherever possible)! plenty of CU's just never this exact one
was just looking to see if any little perculalaritys? could be avoided before i started. :)
thanks again all that replied ( BAS i appreciate the link but customer IS supplying the screwfix jobbie! I take it your not over keen though as the link was for a non MK equivalent?)
:D
By all accounts MK aren't what they used to be. I think that Siemens one is a good price.
No use to me tho - I've just bought a 40-way.
Unless you go to the extra expense of metalclad CUs I think you'll find that all brands are flimsy when it comes to the actuall carcass.
The MK deal on screwfix isn't bad if you can find a use for all of the supplied mcbs.
A better deal is the one from Rexel-Senate.
MK 16-way Split-load, complete with 100A DP incomer and 63A 30ma RCD. All this for £29.99 plus vat.
Mcbs are extra but are only £2.50 each plus vat, and you can choose which and how many you need.
TT
Ban
A better deal is Denmans do their own brand (GE) fully load s/l board 7 x 7 with 14 mcb's for between 69-75, depending on when you buy it.
the thing with buying a brand like MK or hager or wylex (or even volex since there breakers are afaict interchangeable with wylex) is that you know that years down the line the board is still likely to be supported
wylex definately seem the best in this regard you can still buy the old wylex standard boards and i doubt you will see much else of that age still available
finally fitted the above mentioned CU today "flimsy" was an understatement having spent 'eons' correctly alligning all the conductors and earths to ensure there was no undue pressure on the faceplate when fitted(i.e no cables bulging forwards at all) i "confidently went to screw on the face plate.....would it fit right?
would it B***ery!
checked all was level and square many times,same result
finally sorted though
customer very very happy....etc!
:evil: .................... :shock: ..... :( ............ :? ................ :D
What supply rating have you?
Is it 125 amps, or 200 amps, three phase etc - that is a awful lot of power you have... or you live in a giant mansion!
