The mystery of the f&e tank.
18 Jun 2005
Berwickshire
Good people...
Before I start I have to say that I am NOT a plumber so please don't mock this post!! :lol: :lol:
1) Where is the ideal place for the feed from the f&e tank to join the system - i.e beside pump,which side etc etc
2) Where is the ideal place for the expansion to the f&e tank to run from the system.
Here comes the embarrassing bit: What stops the pump from pumping a continuous flow of water through this expansion pipe and into the tank???
Many Thanks my dearies
V
vent------6inches-------feed-------pump-------bypass-------valve(s).
Restriction of the system is what prevents it pumping over, plus correct speed selection.
Thanks oilski. I am assuming in your diagram that the water is pumped in this direction ------ > left to right ---------->>
And what do you mean by bypass and valves. Is this the boiler and motorised valves?
So could the system look like this:
vent----6inches-----feed-----pump-----BOILER-----MOTORSIED VALVE
Ta Ta .. chum :)
No no, he means
Boiler flow -->--vent----6inches-----feed-----pump-----bypass-----motorised valve(s) ===> cylinder on one pipe, rads another.
Bypass (automatic bypass valve, to Return) may or may not be required. See boiler instructions.
The 6 inches can be less.
Don't call the vent the "expansion" - almost all the expanding water goes up the feed pipe.
