- Joined
- 23 Nov 2017
- Messages
- 45
- Reaction score
- 0
- Country
For around six months my Vokera Vision 25C has been making a short whistling noise when the hot tap is turned on. It started intermittently initially but now its everytime hot water is called for. I can’t recall any works to anything when it started. The noise lasts for two seconds max and I assumed it would be fixed at service.
Well today it was serviced. The engineer opened and cleaned the insides, the noise was still present, removed the DHW heat exchanger having drained down the boiler and washed that in the garden – noise still present. The heating system magnetic filter was emptied, inhibitor added and topped up, all radiators bled. Still the short noise.
The noise is not present when the heating is on. It is only present for two seconds shortly after the hot water is turned on. If you leave the hot tap on then its fine until its turned off and on again and the noise returns.
It sounds like a wet finger on a glass of wine and I have some recordings. It seems to be coming from the flue as its almost as loud outside as inside.
My boiler engineer is old school and says he will look into it / call Vokera. I thought I would post on here to see if anyone had any suggestions and I made a video whilst he was here (inside:
Outside:
). Any advice would be well appreciated.
