Hi All,
When installing a socket in a brick/plaster wall, metal backboxes, with the cables coming vertically up from the floor beneath, and the cables fitting inside plastic oval conduit:
Should the conduit run right into the back box? or should it stop just outside the backbox and then the cable run through a grommet into the backbox?
Should both legs of the ring run in one piece of conduit and through the same hole? or should they be in two separate pieces of conduit?
Thanks for your answers,
Slip
Slip
