Themaclassic F35E not heating
26 Dec 2009
Hello,
I live in a rented flat and this morning the heating did not come on. I can hear water going through the radiators and the thermostat and boiler clicks on and off when I adjust the temperature but no heat and no hot water.
I've tried to find info on the web on troubleshooting it but I have no error messages on the display at all. I'm very new to central heating and I'm currently on a internet crash course when it comes to boilers. I have discovered that my water pressure is 0.7 but the boiler should not fail until 0.5 or so it says in the manual. I have been of a mind to try increasing the pressure but I have no clue how to do that. The manual refers to a filler somewhere underneath but does not actually tell me what needs to be done with this.
If anyone know anything about this type of boiler I appreciate the help.
if you aint got a flashing light on the control panel it aint the pressure
if you have the manual it tells you how to top up pressure under "draining and filling"
Thank you.
Regarding the pressure it only says "Fill the system with the external filling device until the pressure gauge reach 1.0 bar" Then it has a diagram showing a tube of some sort with an arrow.
But if this should not be the problem, anyone got an idea of how to troubleshoot this? It sounds like some pump and fan is in operation and being controlled by the thermostat downstairs.
Pump running? OR
Pump & fan running?
'Sounds like'. What? :shock:
You need to be more precise Im afraid.
Paul.
