Sorry Kath, but there's no such product as a thermal membrane that you can go and buy, but I suspect they are suggesting you add something to the wall to make it warmer, but as opps has suggested, you need ventilation and heat to get rid of mould.
The simplest is polystyrene, but that's okay for the back of cupboards, but not much more, and you move up in stages to the likes of WarmaWall that was about 10mm thick, and then you plastered over it afterwards - but that's no longer available. The best method nowadays, is to attach 2x2 battens to the wall, and then put 50mm of Cellotex in between the battens, and then plaster over it. But if you don't sort out the ventilation, then you'll still get problems.
