thermalite blocks
15 Jan 2010
are thermalites ok to use under ground level for the inner skin of a wall? if not what would you recommend
You can get Thermalite Trenchblock that can be used in the ground. They are the full thickness of the wall so you don't have to worry about backfilling the cavity. Hi-Strength 7, Party Wall and Shield blocks can also be used as foundation blocks, although you should check the ground conditions for presence of sulphates.
