- Joined
- 19 May 2020
- Messages
- 10
- Reaction score
- 0
- Country
We recently built a garden office under permitted development in our back garden using thermalite shield blocks. The blocks are very close to the fences around it about 20mm gaps all around. We realised later that the blocks haven't been rendered. Would this be a problem long term? Theres no space to do any rendering now as it is too close to the fences and none of the neighbours are prepared to give access by removing the fence panels. We have had it built for about 13 months so far. When it rains it does soak up the aerated blocks and then drys out. I have managed to put some concrete sealant (water repellant silicone) on the inside walls of the blocks only but only some areas before the plasterboards were installed. The main problem is the outside face of the office, those blocks currently have no protection. Should this be a problem? The inside walls have dot and dab plasterboards. Just normal 12.5mm thick plasterboards. Should this be a problem long term wise in terms of damp?
A few builders have given a few options but none consistent. Some have said remove the plasterboards and put fibre cement cladding and others have recommended installing OSB boards on the outside facing walls and securing with nails but others aren't convinced that this is doable as there isn't enough space to install these and recommended knocking everything down and starting again with solid dense blocks or bricks. Does anyone have any thoughts on this or is knocking everything down the only solution to avoiding damp and damage to the blocks? Some suggested spraying concrete sealant but others felt there is no space to do this.
Thanks.
Rob.
Thanks.
Rob.
