Thermolite or Fibolite
2 Sep 2015
Have my bricky starting on a ground floor build soon.
External - standard concrete blocks
Internal - What are the pro and con of using Thermolite v Fibolite ?
Thank you.
It would be a disadvantage if you used the one that did not comply with the required u-value for the wall
They’re both just lightweight aerated blocks made by different manufacturers. Nothing vastly different between them other than as woody says the effect on u-values
Fibolite are concrete aggregate. Thermolite are aerated concrete. Different blocks.
Thanks both.
so in simple DIY terms, which is the better block? Which has the better U value?
The one your designer specified, probably. Not the one the brickie likes best, or was on offer at the merchants.
But "better" is such a vague term.
