Hi namsag.
The boiler is a Ravenheat 42kw A Rated Condensing Combi Boiler and there are TRVs on every rad in the property.
I agree that in some cases new tradesmen are more keen to learn, so the sometimes know more than more experienced guy's, but the reason I'm checking is that a different Plumber said I don't need one.
I have a bit of an idea of how it all works with TRVs, but not 100%.
The way he explained it to me was, if the main thermostat is set to 17 degrees, but you have the living room TRV set to maximum as soon as the main stat turns off the boiler it will shut down the whole system. Therefore you may never get the desired temperature in the living room.
The way to overcome this is to set the main stat to maximum and then adjust each individual TRV. Instead of doing this, don't use a main stat, turn the boiler to the temperature that will exceed the maximum TRV and let them shut down the flow from the boiler.
I don't know if this is correct, but seems plausible. My only concern was, does the boiler itself have an internal stat and if so will it keep heating water in the pipes (not rads) to keep it to the temperature that the boiler has been set.
I don't care what I have to do, but I want the system working properly.
Thanks.
