Ive recently replaced all my radiator valves with TRVs and installed an automatic by-pass valve in my airing cupboard. My plumber has told me I needn't remove the old room thermostat (mounted in the hall) but merely set it to maximum so that it doesnt override the TRVs - including the one in the hall. I have also retained my combined CH and HW programmer (linked to a 3 way valve) which switches off the boiler overnight. My question is whether this is the most economical way of using my TRVs or whether I should remove the room thermostat.
Also, can someone please explain why, when the TRVs are shut off, it is still more economical to have hot water circulating all day through a by-pass valve in an un-thermostatically controlled airing cupboard than a non-TRV system which just turns off the boiler when the room thermostat reaches the required temperature?
