Thermostat permanently on- help!
27 Jun 2010
Invernesshire
Hi folks,
I think my thermostat is goosed because the pump is going all the time at the moment.
We have a multifuel stove linked to the thermal store and for the last few nights I've heard the pump running constantly when it should only kick in at 65(maybe 75?)c. After the fire going all night keep waking to a tank temperature of such low temperatures(25 bottom/35 top) on the Resol display I know something is wrong with it, usually wake to 55-60 degrees.
The make is a Codice 542496 and along from it is an I-stat Dual with what seems to be a setting dial that goes from 60-90 and is set at about 75(I think it is the only way I can see it is by photoing it because it's stupidly inaccessible)
I don't even know for sure if the two are linked, sure they are though, does anyone know if this make is any good? It's lasted under 3 yrs and it seems my neighbour has had his replaced already, same age of house. Can it be replaced easy enough with another better, reliable make if this brand is indeed pish, and could anyone advise a good make? The Istat controller thing is loose on the tank and seems to be hanging by a copper/brass nipple?
Could I do this DIY or should I get it done by a plumber OR sparky?(not even sure who's realm this is in!).
If I need to call someone out what could I expect to pay in terms of time?
The whole tank is in such a stupid place too, everyone involved in the design and build of this place must have been on crack....
You should get a decent Service Engineer in who understands thermal stores
as regard to how much?? from your description of your badly installed system- Impossible to say but it sounds like a long visit may be needed!! :wink:
I came across your problem, I'm having the same issue with my tank.
It's the same thermostats.
I'm not clear on how the dial reads as it's poorly designed and there are no instructions or clear indication. Perhaps I'm setting them wrong.
My dad has simultaneously installed the exact same system and he too has the same problem. The thermostats seem to click at the temperature of the water, they are staying on as well. I have to manually click them off or shut down the power.
I'm maybe missing something? Or there is a problem with these Codice 542496 thermostats?
How did you rectify the problem?
Thanks,
Charlie
