Hi everyone-@Happy New Year, if its not too late for that..!!..Its my first try at posting a question, so fingers crossed..
Moved to a house with TRV's fitted, 'Myson TRV 2 WAY' is on their tops. Do they wear out?..or break? My problem is several of the radiators will only heat up if I unscrew the top part of the valve from the bottom part, and then the rad.is full on.There is a 'plunging' bit that moves down out of the top part to connect with the pin in the lower part, and as you turn the control mechanism top around the lower part on the top housing, this can be seen to work. The pins poking up out of the part of the valve plumbed in to the radiators seem very stiff and so I have tried to loosen these a little, forcing them a few times in case the pins have just got stuck, and everything else I can think of (including WD40 !!)..but then put the valve back together, and it still just turns the radiator off.
I am kind-of angry with myself as I have not yet cracked this, as (usually..) I'm pretty good at stuff like this..
..Help, anyone, please..
