    Dismiss Notice
Thermostatic shower and bath filler not hot
Discussion in 'Plumbing and Central Heating' started by abza, 25 Jan 2021.
  1. abza
    abza
    10 Sep 2008
    17
    Thanks Received:
    2
    Yorkshire
    Country:
    Hi everyone.
    I have a bath with overhead shower the bath is Bristan quest or something like, the overhead rainfall shower is a good brand from stax. Sp I think. Both cost over £150 so not cheap. But neither has water coming out hot enough just a little better than lukewarm unless I restrict the flow then I get a hot trickle.
    The bath is obviously more of a problem. The basin is non thermostat so lovely and hot as is kitchen and ensuite shower.
    Now the pipes right up to bath filler are 22mm and the same pipes feed the basin which is lovely and hot.
    Obviously if I control the flow the water will get hot but it takes ages to fill the bath and can’t really enjoy a rainfall shower when it’s slowed to a trickle.
    To mimic reduced flow I’ve restricted isolator valves but again I don’t want it to be a trickle.
    I’ve taken off the quarter turn fitting and turned valve on hot and refitted cap so the cartridge is turned to max. Nothing.
    I’ve obviously played with button for the anti scold safety again nothing as I’ve taken the turning cap off and moved it maximum anyway.
    So could anybody suggest what else I could do. Thanks.
  2. dilalio
    dilalio
    20 Mar 2009
    7,774
    Thanks Received:
    1,249
    Potters Bar
    Country:
    Are they high or low pressure valves?
    What hot water system do you have?
  3. Sponsored Links
  4. abza
    abza
    10 Sep 2008
    17
    Thanks Received:
    2
    Yorkshire
    Country:
    Sorry it’s a combi boiler. Main 30kw. The boiler is fine though as it’s really hot everywhere else.
  5. dilalio
    dilalio
    20 Mar 2009
    7,774
    Thanks Received:
    1,249
    Potters Bar
    Country:
    Remove thernostatic cartridge and test water coming straight out of valve.
    If you get good supply then the cartridge needs cleaning/replacing.
    You might also be getting crossflow.
  6. Sponsored Links
  7. abza
    abza
    10 Sep 2008
    17
    Thanks Received:
    2
    Yorkshire
    Country:
    Ok so I did remove cartridge on both the shower and bath filler and saw that they were retracting as I turned so appear to be working ok. What is crossflow?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
