I've fitted a new bathroom and put in a shower cubicle. The thermostatic bar does not work very well, it's difficult to regulate temperature and it groans and pulses or nothing comes out at all.
The hot water comes from an old gravity fed system, and the cold is off the mains as opposed to the cold water tank (as it was easier for plumbing). Is this my problem? I've crudely used an isolator valve on the cold mains side to get the pressure down to the same as the hot, but I'm guessing this is not accurate enough?
Would a difference in hot/cold pressure give the symptoms I'm describing on a thermostatic bar?
