thermostats
25 Nov 2004
boiler classic ff250-boiler goes on/off every
minute roughly pump keeps running but romstat and cyl/stat dont reach set point
even when run seperate any help appreciated
thanks for reply fitted new 3 port valve but problem still there
are the rads getting hot at all?
Is the water from the taps hot?
water does get hot after a while/ one rad in hall way gets fairly warm
others virtually nothing/pipes to rads are warm but seems to end there
have drained and filled afew times.sounds at times as though their is air
in system around the boiler. property is/bungalow with cylinder/pump in
the loft dont know if this is any help. thanks for your help.
there is a 15mm bypass at the pump, boiler is not really noisy,makes a
slight noise when it comes online,but i think this is from the fan.
thanks.
