Thick or thin bed adhesive
9 Jul 2006
//www.diynot.com/forums/viewtopic.php?t=58186&highlight=
for reference purposes only
i have finished tiling the floor (real tiles on a laminate structure (edge tiles from b and q)-no slivers -3 days work i'm well chuffed but tired
anyway onto the walls now. gcol has given me good advice for tiling but i have a problem
two walls are not quite level. where the window meets my aquapanel there was a gap. it had been tiled over previously but the tiles had cracked. i have filled that area level with the wall.
the second wall is where two rooms were knocked into one. the two surfaces are level for 80% of the wall but 20% there is a slight difference
a batten against both surfaces shows a difference of maybe 2 millimetres maybe 3 max. a batten levelled against the surfaces shows this gap. it is a small deviation.
can i get away with it with a reasonable amount of adhesive. should it be a thick bed adhesive to counter this and if so what manufacturer would you reccomend
the pic shows the filled area next to the aquapanel. the other area can be seen from the pic as an oblong shape right of my basin pedestal which is a different colour -brownier rather than pink
i posted this in the wrong section didn't i -doh!
please ignore-i'll post it in the right section
