I am planning to use Aquapanel around shower cubicle and above bath (Aquapanel on timber stud wall, and finished surface will be tiles). I am in two minds about the best way to do Aquapanel joints. Knauf produces two leaflets with two different guidances: one says to leave a 3mm gap then fill with tile adhesive and bed in tape; the other stresses the importance of cleaning board edges as you go, applying special aquapanel joint adhesive then butting up close, thereby squeezing out adhesive, and trimming off excess the day after when it has cured and expanded.
The latter, using the joint adhesive, sounds better to me, but when I rang their tech support, they were non-commital, if anything favouring the 3mm gap plus tile adhesive method.
Anybody have experience of both? Any recommendations?
Thanks.
Thanks.
