Just want to check thoughts of others before calling the heating engineer out. I’ve got a Greenstar 32CDI. For the last month or so the pressure has been dropping about 1 bar in 3 days. Have done all the checks on visible pipe work, can’t see any water on ceiling etc. also checked the expansion valve for drips.
It’s now started going down 1 bar in a day. I have now just had a good check of the external condensate pipe, and with the boiler not in use, it’s dripping about once every 5 seconds.
Is the only possible cause of this a cracked/pinholed HEX? Or could it be a blockage. I’m assuming with the pressure dropping as well it won’t be a blockage.
One other symptom is I hear gurgling under the boiler sometimes when it is running. Not always though.
