I have a concealed cistern in my bathroom, which appears to be a TD vantage concealed unit. I've removed the front panel and the valve is closing when the cistern is full. However, water trickles into the pan and, when the water is off, the tank slowly empties.
I have fairly limited knowlodge of toilet systems, but I believe I'll need to replace the washer at the bottom of the pneumatic valve. A couple of questions...
- how do i know which washer I need? Does anyone know the part?
- can i replace this part through just the front access panel, or will i need to get to it from above? Also will I need to remove the front panel which the pan backs on to?
Many thanks
Many thanks
