I am looking for some advice on a problem with my Thorn Apollo boiler and open vented heating system. Over the weekend, I took out my old bath suite and replaced it. This all went well, including the replacement the radiator.
I had turned off the hot and cold water feeds in the loft to drain the hot and cold pipes, but didnt drain the CH for the radiator (just cut the pipes and used push fits to quickly connect the pipes, but lost very little water).
Rather stupidly
, I didnt turn off the boiler timer, so whilst the water feeds were off the boiler kicked in. Now, when I turn the boiler on, it fires up, making a slight whoosing noise, then the pipes above the boiler make a loud banging noise and the boiler soon switches off.
So, I assume that for one reason or other, the water is not circulating thru the boiler and overheating, therefore triggering the boiler to switch off. I have checked all the rads and water is coming thru the vents, little or no air.
Could anyone kindly advise what the best method would be to cure this (as we currently have no hot water to enjoy our new bath etc.
) From reading the other entries I guess this might be to drain the system, to ensure there are no air blocks) or that the pump might need replacing. Could you confirm how to check if the pump is gone or if the pump overrun thermostat needs replacing?
Many thanks!
Rather stupidly
Many thanks!
