Can anyone give me some advice ? I have just moved into a house with a Thorn back boiler that seems about 100 years old. There is an ugly 70s style fire called a 'Housewarmer' attached to it in the living room. Our hot water is scolding but we can only fill one bath before we run out. The radiators are lukewarms somedays, boiling the next - no two days are the same. I have checked and the radiators don't need bleeding. Also ( pardon my ignorance here) but I can't turn the radiators up or down . There is a valve with a screw in it but when I unscrew it I can't get the valve to move and so radiators are on in rooms we don't use. Also are we supposed to leave the water switched on all the time or is this costing us a bomb ? Also the whole thing makes a racket - a sort of whoosing sound behind the chimney - which I'm sure is normal - just annoying
What we would like to know is:
Is there anything we can do to improve the above with the present system ?
If we install a combi boiler instead will this improve things or will we need to replace all the radiators too ? ( we are trying to persuade our landlord to replace things so need to give him options)
Can we replace the ugly fire in the interim or is this connected to the whole thing and can't be replaced?
Any info would be gratefully received as I know absolutely nothing and have never had central heating until now. Also I don't want a nasty gas bill because of an ancient system.
Thanks so much.
JC
Thanks so much.
JC
