Thresholds that stick straight on top of flooring???
20 Nov 2006
Is it possible to get wooden/metal thresholds that stick straight down on to the bottom of door ways for different rooms (i.e. don't have a base that has to sit under one floor and the strip attached to it).
I have wood flooring that runs through different rooms and the gap is not big enough for the usual thershold strip to be put in so just want to glue down strips directly on top of the existing floor if possible - the floors in the differing rooms are level.
If your wooden floors are at the same level we do do wide strips (beveled on both long sides) you can pin down to the floor. Solid Oak strip 35mm wide
