I'm using m12 120mm through-bolts to bolt 50mm timber to a wall. Around 1 in 5 don't seem to grab and will just pull back out as I tighten up the bolt.
Is there a knack? I always aim to avoid the frog or any bed/perp, and being careful to try not to punch through the back of the brick but that doesn't seem to matter. The hole in the timber and brick is drilled at 12mm too, so the bolts are tight and need hammering in.
