Hi there - new to the forum, but I hope there is someone out there who can help me with this!
I've always had a problem with a "ticking" / "tapping" noise (not an air-hammering / water-hammering type noise, more tinny & metallic) coming from a Tower 3 port / mid position valve. This is annoying, but given the difficulty in accessing the valve body, I just ignored it. Valve recently failed, so I thought I'd swap it out with a Honeywell V4073.
The new unit is making an identical noise, but with an unfortunate increase in volume(!); which is now loud enough to wake people in the house (noise is transmitted efficiently through the pipework, so affects every room). The valve is allegedly good quality, and brand new.
I have tried everything (I can think of):
1) flushed all the air out of the system under 'closed' conditions (i.e. mains fill on closed system (open), all radiators bled & sealed (valves left open); only opening is drain down on lowest point - flushed at mains pressure until clear of bubbles for 2-3 gallons),
2) checked for transmission of boiler noise (no noise from ravenheat system boiler),
3) reduced pump flow rate (no change to noise generation)
4) Flushed system at full 22mm pipe bore (not via drain valve) to remove any grit / debris / sludge
5) Checked all wiring & functions, all working as they should with correct voltages & valve movements when triggered by cylinder / room stats & boiler call (control unit settings)
6) 15mm bypass has been fully opened up to ensure adequate flow through the heat-exchanger (avoiding kettling)
7) verified AB port is connected to boiler output, not return
8) verified correct setting of air release valve on top of the boiler, and at the expansion vessel (integral to the system boiler)
9) bled the standpipe in the loft
10) run the system on minimum & upper limit of operating pressures (no change in noise generation)
When valve is in either A, or B position (i.e. ball seal wedged against pipe opening), no noise.
When in mid position (between common AB, A & B ports - for CH & HW), I get the ticking. I upgraded the brand to avoid this problem, but as far as I can tell the two units (the tower, which I replaced, and the honeywell replacement) are identical - despite the honeywell costing a good £30 more.
It seems I've more or less ruled out electrical problems, and air in the system; as well as water pressure / flow; so I'm thinking that it has to be the valve(?)
- is this a common problem (i.e. 'just the way it is')? Or is this a faulty valve that needs to be replaced (again)? Could it be valve orientation (currently mounted vertically, with AB right, B top & A bottom)?
I'm now pretty much out of ideas, so any help with a cure would be much appreciated!
