- Joined
- 19 Sep 2020
- Messages
- 28
- Reaction score
- 1
- Country
Hi
I have a stone wall retaining the land at the back of my house before stepping down into the garden. A structural engineer has said while it's fairly solid there's a little bulge and he'd like to see some re-enforcement of it and advised building a wall at 90 degrees to the retaining wall.
I've decided to make the best of this and build to walls parrallel with each other against it.They are to be infilled and become a ramp down to the garden. I'm wanting to build a little out-house at the bottom of the garden so access for mini digger/barrows will be really useful.
Question 1- I'm wanting to tie the dense concrete blocks I'm using into the joints of the stone wall however the course will never match - I was looking at using these https://www.bricklayersmate.com/ancon-staifix-starter-tie-3354-p.asp
does anyone know if they will be up to the job or are they to be reserved only for brick?
Question 2 - what would be best to fill the ramp with? I essentially have two 6m sloping walls 2metres apart, starting at 1.6m trailing down to the ground that need infill in between. I want it to be strong enough to take a vehicle if necessary... In my mind I thought rock then hardcore to gravel topped with patio slabs?
