- Joined
- 29 Apr 2017
- Messages
- 7
- Reaction score
- 0
- Country
Hi All,
Ive been using the answers from this forum for some time and its invaluable.
Q
I am to remove (done) a 400mm column of existing brickwork, internal wall but was previously external and is certainly load bearing, and replace with 330mm minimum of new engineering brick pier. The problem is that the engineer requires it to be bonded in and not furfixed. The issue is that the existing wall -of which I removed 400mm - is perpendicular to existing exterior walls, I cut it off flush to the walls which will remain and planned on cutting / mining 120mm x 3 bricks high cavities into which to place my teeth.
But:
On the right side of my cavities is a window, so they have no border on that side, just window frame, and on the left is what was left of an old flue which angled down into the room from above and has been removed with the void bricked up, so no brick bonding there either.
On the rear face of my cavities there is little or no bonding to external skin - its a double thickness, no cavity victorian wall. So basically once I had created my cavities the remaining segments of old brickwork fell down leaving me with a a full height (3m) and full depth -at least 150mm - vertical trench or one great big cavity.
in plan form the wall Im removing forms a T section rotated 90 degrees to the right, basically a perpendicular internal dividing wall.
So please help!
How do I tooth in to exoisting brickwork which no longer exists? I guess I could furfix or else create teeth by bonding into the external skin or perhaps by teething into the bricked up old flue to the left.
There are other iussues but one thing at a time!
D
Q
But:
So please help!
D
