I’m hanging a ceiling fan & have put the bracket on with the two screws. One of them is almost screwed in fully but has stripped before I could how can I tighten the rest of this up it was quite tight as I was screwing hence the reason it stripped.
Grip the sides of the Head as if you were trying to cut the screw in half lengthways.
They will bite into the Head and you should have enough grip to undo the Screw.
