Tightening kitchen tap
13 Jan 2012
Blackpool
Hi all. A while ago I got a replacement kitchen tap. The previous was a fairly standard monoblock with a metric threadded rod (maybe M10 or something) and a brass nut holding it into place. The replacement appears to do away with that and comes with a threaded tube, maybe 45mm in diameter and a plastic nut with a hint of some kind of grip to assist thumb tightning. Only trouble is, the thing is damn hard to tighten. Can't seem to get it tight enough and don't have a 45mm box spanner in my set.
Is there a special knack/secret/tool for tightening these?
It needs to be tightened properly but there is little or no room to get some grips on to it. Just buy the long box spanner and make it easy for yourself
Blup
Just to add.
I be taken the last two sinks out. Fitted new taps and pipe tails and dropped back in. Used clear polymer mastic to reseat sinks.
Just to difficult to get under imo. Takes 5 mins to unscrew sink clips and lift sink out.
Plastic nuts are rubbish. Even if you can get it tight enough to prevent the tap from moving the chances are you will strip the thread.
