Four-in-One Portable Laser Level: High Precision Line Device with Double Bubble and Low Power Consumption
Features 1、Vertical and horizontal high precision double bubble, can ensure the accuracy and stability of measurement. 2、Use two no. 7 battery specifications, low power consumption, medium use can reach more than half a year. 3、Its body is light and small, easy to carry, can work anytime and...www.diy.com
I just seen this fir 16 quid from B&Q Might just buy it
If you watch skillbuilder laser level tests on YouTube it's interesting.
I do like the green lasers although mine is red. Tests say no difference but I think green is better to look at.
Depends what you want from it I guess. I used mine for wallpapering above windows and door.
Checking alignment of shelves.
That was about it.
String plumb line and sprit level mostly
I might be wrong, but it looks as though it is not self leveling. If so, you will be relying on the two small levelling bubbles on the top of the unit. That means you will need to set it up, walk to the other side of the room and use a long level to check the accuracy, then walk back to the unit to adjust it slightly.... and rinse and repeat.
I note that it says that the line thickness varies from 0.5cm to 1cm.
I guess it is better than guessing if something is level though. Sorry, that is the most positive remark I can make.
Just buy the tiktok one.
It's green
Self leveling
Cheap.
What could possibly go wrong. Ha.
