Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
hi m8 the 1 you want is a rubi ts 50 its got spare scoring cutters 10mm +6mm look on ebay although £160 you can get them for £100 the thing i like about them thay dont bend as the braker is on its owen at the end
if you are dowing floors you will need ts60 but you will do most jobs with ts 50
Rubis are good, but just be aware that if you ever want to lay any tiles in a diamond pattern, you'll not be able to do it with a rubi. You'll need a cutter with a moveable breaker.
Well it depends on a few things:
1) The quality of the cutting wheel.
2) The quality of the unit itself. (How it holds and supports the tile is important.)
