Tile/grout/mastic advice around bath please!
27 Feb 2017
Essexshire
I’m replacing the bath screen and re-masticking the bath. I’ve removed the screen, removed the taps (will be too difficult to mastic with taps in situ as very little space between taps and wall) and removed the old mastic. My problem is that at the tap end, I have an 11mm gap between the tile edge and the bath top. I filled it with mastic last time I did it but Mrs Mottie says it looks like I’ve just squeezed the toothpaste tube out! What would be the best way to fill that gap and mastic? I was thinking of getting some waterproof grout, go all round the three edges of the bath, let it go off for a day, mastic and let that go off for another day before fitting the new bath screen. Is that right or is there another way?
L shaped Bath trim
Urgh! Going to fill the gap with waterproof grout and then mastic it. Trim might be a last resort and I may have to cit around taps - they are that close to the wall, but at the moment, that idea is a no from the boss. :(
Turns out, I’m fecking useless at masticking. :ROFLMAO: Got a mastic man in in the end and while here, I had him do bits all over the house. I won’t try that again!
Get yourself a set of finishing tools for mastic: they make a huge difference.
I did. Made no difference. The professional just spat on his fingers and wiped it!
Human saliva will encourage mould growth and a concave shape left by the finder does not shed water well.
So he may have been experienced but not very professional .
:sick: Was wiped over with a bleached cloth when it went off. Fingers crossed…
