I've got a few dips in the floor, nothing major just the shape of a brick and maybe an inch down (max). Can I just pop my DPM down and ballast over it rather than having to fill it first.
The DPM won’t mind the odd undulation but a one inch depressions the size of a brick I’d rough fill first.
Secondly I've got a few bits sticking up where they've put a but if concrete down to sit the old joists on (a lining of old brittle DPM is stuck to it too. Can I just forget about this too?
I can’t really tell how significant or high the bumps are from the picture but if they are of similar size to the depressions, I would level them off; I wouldn’t be too concerned about the old bits of DPM.
You need to get the DPM laying as flat & as close as possible to avoid any creases, rucks forming or voids underneath when you pour the ballast over it.
And lastly theres a few bits of render missing from the walls, can I just lay the DPM and forget about them too?
Should be OK but bring the DPM up the vertical edges of any walls around 50mm higher than floor level & cut it off flush when you’ve laid the ballast.
Oh one last thing.... where the ballast meets that of the hallway the finish of the hallway edge isn't smooth (it's jagged) shall I paint some synthaprufe on the jagged egde and allow the new ballast to meet it? I've got that in two places actually.
I’d slap a couple of coats of Synthapruf on it & bring the new DPM up around half the height.
By the way.... when I lay the new DPM onto the old, do need to attach it or just overlap it?
Overlap it & as above/below, bring the new DPM up vertically around half the height.
Also... do I need to do antything with the edge that I'm ballasting up to that's already been done?
Slap a couple of coats of Synthapruf over it & bring the new DPM up around half the height as before.
Are you pouring over those Speedfit plastic couplings? I don’t like Speedfit full stop or plastic for that matter; personally, I wouldn’t be happy with that. To comply with BS installation & water regulations, plastic fittings and pipe should be removable for possible replacement & Manufacturer’s recommend they be installed in a conduit pipe with access boxes for the fittings.
Similarly, copper pipe should be accessible (mine are in a break out ducts filled with granular Vermiculite) but as a minimum, you should lag the copper pipes with Denso tape or something similar; cement corrodes copper.
