Tile Position
11 Jun 2004
Hello all,
Quick question I have a kitchen wall to tile which incorporates an extractor under a fan unit. When working out tile position do you start from the centre of the extractor and work outwards to the outer walls so the tile spacing is uniform around the extractor or do you take the centre of the whole wall and work it out from there. Cheers in advance
I usually set it out from the center of the hob / extractor. Depending on tile size and who the end cuts work out you will either have a central joint or a tile centered over the center line.
Jason
