Tile trim which hides both tile edges
30 Mar 2015
i am looking for a tile trim which covers both edges of tiles and looks good around a window reveal please.
Let me elaborate. My tiles are unlikely to be dead straight around the window edge and my cutter usually leaves small chips on the edge. I am after a tile trim which wraps over this edge and the inside edge too. The metal trims (I prefer white plastic) appear to reveal the tile edges.
How can I achieve this?
I think they will look awful. I’m surprised that there isn’t a trim which has a “lip” across both sides...
It’s not just chips, but my tile edge is also unlikely to be dead straight as some may be a mm or 2 larger or smaller than others. Such a trim would finish this off nicely.
I’ve seen lots with a single lip but haven’t come across one which does both sides.
I’d really appreciate any suggestions
I’ve been doing some more research on this subject and wanted to run something past you please. Should I not be aiming for a full tile above, below and on the sides of a window wherever possible? This will mean that I always have an uncut tile end against the trim?
When it comes to the inside of the window reveal, I should always put the cut end next to the window and again, have an uncut end against the other side of the trim?
I can then apply sealant against the window and tile ends to hide any imperfections.
Can I get your view on this please
I suggest more practice on your cuts for when its unavoidable to have cut edge against trims but plan to get the least against them while maintaining layout balance.
