Tiles on chipboard and hardibacker
2 Feb 2012
Ok so I brought some 6mm hardibacker from topps tiles as a better base for my chipboard floor
The problem is I can't find any nails at all for the chipboard so don't know where to screw int joists to strengthen the boards.
They are fairly stable so was going to add a layer of adhesive then screw the hardieboard onto that
Do you think it will be ok to then tile onto that or am I going to have problems with cracked tiles later on.
The floor area is literally only 2m2 so not much movement but after reading comments on the net I'm a bit worried
If no nails/screws visible....sounds like it may be a block and beam floor
Is it ground floor...?
Just do as you have stated...I.e..adhesive/hardie/screws..tile away...
Yeah ground floor, there's a very tiny amount of movement but I'm going to add the hardibacker and hope it gives a better base
Also, I really want some porcelian tiles that I have seen but worried they are going to be hard to cut. I do have a wet cutter and gonna buy a new wheel for it. I don't have that many cuts to do so hopefully it will be ok.
Stagger the h/boards...brick effect...
Porkies are very good tiles....any good dry cutter will cut them with ease...just run them slowly thro your wet cutter,you don't want to be chipping the edges
Do you have skirting boards to go back down ontop off tiles,or you using silicone.
I do have the skirting boards but was thinking having a small border out of porcelian so can do either way really. Obviously the skirting will cover the cut edges I suppose.
The dry cutter I have is a plasplugs protiler, not the greatest so not sure I wil be able to cut the with that, will have to use my wet cutter and try and cover the edges
