Ok so I brought some 6mm hardibacker from topps tiles as a better base for my chipboard floor
The problem is I can't find any nails at all for the chipboard so don't know where to screw int joists to strengthen the boards.
They are fairly stable so was going to add a layer of adhesive then screw the hardieboard onto that
Do you think it will be ok to then tile onto that or am I going to have problems with cracked tiles later on.
The floor area is literally only 2m2 so not much movement but after reading comments on the net I'm a bit worried
