I'm going to be tiling a dining room floor with porcelain tiles 300x300 which will be put down on 6mm ply which will be fixed to good floorboards.
im taking a lot of information off the internet of how I should do this correctly and successfully ie how do I fix the 6mm ply down do I screw every 6in or nail pins? then do I prime the 6mm ply before I tile? also how far away from the skirt board to I board up to?
all help appreciated
Thank you
Thank you
