I normally leave 1-2mm,especially behind the sink.
ive never left a gap and had no problems. if the worktops are secured securely there shouldnt be a problem.
Thanks for both the replies but that still makes me undecided.
Why behind the sink?
Yuk, that's even more unhygienic than using grout! I personally have both black worktops & black tiles & if you use a 2mm tile spacer the silicone, done properly, will look no different to a normal grout line; you don’t need a huge globbed bead along there!I have decided to leave a tile spacer gap as suggested. I didn't really want to silicone the gap as i have black worktops and didn't really want white silicone.
I may try that if nothing else works. ThanksIf you use clear silicone it will look dark grey.
