Tiling bathroom, where to start.
24 May 2006
I'm going to be tiling the bathroom walls and floor, do i remove the skirting and leave it off, if so would i tile the floor first and then butt the wall tiles upto them or vice versa.
thanks
I always tile the floor first and then the walls (with skirting removed) down onto the flooring, with a 2mm gap.
I prefer to leave the floor till last, so as not to drop stuff on it while tiling the walls.
Although in some circumstances i've had to do it the other way round and protect the floor as required. :)
What is the normal way to tile a bath room. With skirting or tile to the floor ?
Don't put any more tiles on than you have to - it's soooooo '80s.
If you want to retain the skirting and sit tiles on top, you have thick skirting. If not, the tiles will sit proud of the skirting and it'll look pap. Alternatively, you can stick the skirting to the tiles, but to my mind, if you've got to go to that trouble, I'd just do away with the skirting and run the tiles to the floor.
