Hi everyone,
This is just a preview of the problem I'd run into if I didn't prepare my surface. Please note, the tiles there have not been laid yet.
The concrete (in purple) is higher than the blue tiles. I thought of boarding down with ply and packing underneath where necessary, then I will have to do the same where the blue tiles are which I can't do because the ply can only be 18mm thick and I don't think I can lay battens underneath because it would sound hollow (presumably?). Other option is to hack away where necessary at the purple concrete, but would be one hell of a job. I've tried it and it is as solid as a rock . Perhaps I could raise the step that those tiles are laid on with cement and sand? Although it would be too thin . I just don't know what to do .
Does anyone have any advice if you were in my shoes?
Maybe use 3 sheets of 18 mm ply on the step and 1 sheet on the concrete and they'll be at the same height then? It' just this rule that's bugging me about having to use 18mm ply.
Thank you.
P.S. Notice how out that spirit level is lol?
Thank you.
