Tiling new bathrooms and en-suite room
27 Jan 2020
I am currently having some work done in my home and have not long had the skimming finished in the bathrooms(approx 2 weeks ago) with a view to retiling and new shower enclosures etc.
My question is that a) Is tanking the shower enclosures an absolute requirement
b) and if it is , can newly skimmed plaster be tanked and any recommendatons as to what product to use?
Any feedback would be greatly appreciated.
apologies, eyesight not what it used to be.The walls are NOT plasterboard
Normally tank with plasterboard as it fails completely when wet. Skimming was not required if you are tiling.Needs priming , not tanking.
Following this, as will soon do same.
What is best practice for showers these days? I have solid walls plastered, with space for either moisture resistant plasterboard or tile backer board.
Went to B&Q to look at tile backer and member of staff told me moisture resistant plasterboard would be perfectly ok.
Is that right?
Is that right?
No , plasterboard will turn to mush when wet. You can tile directly to plaster, prime first.Though my personal preference is for shower panels, only a few joints , less risk of failure, easier to clean.
It will need some board as there is a 10mm or so gap between the shower edge waterproof tape (not sure what its called) and wall.
Hardie Backer board? Might look again at shower panels ...
In response to you plaster requiring priming only, do you have any reccomendations for primer?
