It’s not recommended to tile over bitumen adhesive but the problem is that the stuff is almost impossible to remove by mechanical means (it just goes soft) & solvents are not practical for health reasons & risk a possible reaction with the adhesive.
Best advice I can give is to remove the thicker/uneven/loose bits, make sure it’s clean & no grease, prime with an decent SBR based bonding primer & tile using a flexible cement powder adhesive (Rapidset Flexible). Neither I nor the adhesive manufacturer will guarantee it but I’ve tiled onto a couple of old kitchen floors without any comebacks. Some recommend priming with Ardex P82 primer but I’ve never tried it; only bullet proof approach would be to put down a self leveling screed & then tile over that.
Thanke for the replies fellas. The floor was pretty uneven so in the end I got most of it up with a sds hammer then put down self leveller.
I often use sbr slurry mix when plastering , handy to know it can be used with tiling too. Cheers
