I have some large 12x12 tiles about 8mm thick, which will run around the bath / shower. However the walls are not completely level and if i use a solid bed of adhesive unless i lay it really thick the tiles won't level.
Is there any reason why i can not use adhesive beind the tile, using the four corners and middle, which will make it easier to adjust, are there any disadvantages to this method as opposed to a solid bed.
