Timber for battening
16 Oct 2012
London
I am going to batten a wall for my bathroom and will use aquapanal as the backer board. What kind of timber do I need for the job ?
25mm x 50mm tanolised roof battens.
...Or consider 19mm x 38mm if you want to save a bit of space but lose stiffness.
Ooer.
Thanks noseall. Do you know where I can get tanolised roof battens ? Are they available in wickes/b&q etc? Or will I need to go to a builders merchant ?
They are a very common stock item for any timber or builders merchant. I would image b and q and the like must have them.
Thanks. What about screws ? What size screws should I use to batten the wall ?
Probably 75mm #5's, 7mm drill bit and brown plugs or similar depending on the masonry.
You may get away with shorter slimmer screws if the masonry is solid.
