- Joined
- 5 Jul 2017
- Messages
- 3
- Reaction score
- 0
- Country
please see https://www.diynot.com/diy/threads/share-your-diy-projects-with-us-no-queries-please.74081/
I am in the early stages (not started yet!!) of a single garage build and just after some advise on a few things! this is the plan so far......
7mtrx3mtr concrete base with a dwarf wall
4x2 timber studwork framework sat on top of wall
the plan is to use knauf aquaboard on the outer skin then render onto it,now this is where i am a little unsure as i will at a later date insulate between the studs and may either plasterboard or ply line inside,am i best putting some kind of membrane over the 4x2 then adding a slate batten then attaching the aquaboard on the outside? or is there a better way to do this?
