Can I use the permitted development rights to build a 3 metre rear extension on my house? There is no prior extension.
Additionally, can I build this with timber stud work, rubber roof and then plaster externally? If yes, do the foundations need to be any less substantial?
I prefer this as I can do all of the work myself and it would look no different externally, once everything is finished.
I can insulate it externally and again, once it is finished internally, it would look the same as a brick construction.
Wanted to check if the building inspectors will be okay with this and if there are any other considerations with this approach.
Thanks in advance.
Thanks in advance.
