BC107s aah, that takes me back
It's the OC71 that does it for me...
Was that the one where you could scrape off the paint to make a photocell, or was that the red spot transistor?BC107s aah, that takes me back
Slightly more complicated than I was hoping for. Might buy him an effing stop watch.
The BC107 series (certainly BC109) are actually still in production. I have a large stash of them and I regularly use them as general purpose NPNs - and BCY70s for PNP.BC107s aah, that takes me back, lad! I've come over all nostalgic. I wonder where I left my Heathkit radio......
Not old enough to have been brought up on red spots and white spots?It's the OC71 that does it for me...BC107s aah, that takes me back
Both, and others - in fact all those early transistors where the works were encapsulated in something semi-opaque and then covered with black paint. I think nthe OC170/171 were the first I used which had a metal 'can' - and that was, I think, done for 'screening' (ISTR a fourth lead connected to the case, but I may be wrong).Was that the one where you could scrape off the paint to make a photocell, or was that the red spot transistor?It's the OC71 that does it for me...BC107s aah, that takes me back
Kind Regards, John.
............... or was that the red spot transistor?
Ah! It's nothing to do with me going (or not) to Specsavers, but, rather, to my ('dangerous') habit of enthusiastically responding to posts as I come across them, without always thinking to look ahead to what has been written subsequently! Anyway, I'm pleased to hear that there are some around as old as meoh yes I am.Not old enough to have been brought up on red spots and white spots?You should have gone to Specsavers............... or was that the red spot transistor?![]()
It was the OC71, there was a version with clear gell and no paint called the OCP71 intended for use as a photo transistor. It sold for about 3 times the price of the OC71.Was that the one where you could scrape off the paint to make a photocell, or was that the red spot transistor?
............ my ('dangerous') habit of enthusiastically responding to posts as I come across them, without always thinking to look ahead to what has been written subsequently!
Kind Regards, John
I know, and I cursed them for it - although I did by then have a reasonable stockpile of 'scrapable' OC71s. Indeed, I'm sure that I must still ahve some in the cellar!Then Mullard started using opaque gell in the OC range of transistors and one had to buy the OCP71.
